Racer X
SHO Pilot, Retired
$52. Shipped. God I love eBay!
Racer X said:$52. Shipped. God I love eBay!![]()
nkb93 said:Congrats! I think that's the same one I was recently bidding on! (ending price was similar) I thought I was being sneaky by bidding at the last minute, but I got out-sneaked..At least it went to a fellow SHOwner, and not for some clunky Dodge POS. I felt kinda bad bidding on it since the initial bidder had just won an auction for an ABS hydraulic unit.. so you know he REALLY needed the bleeder... oh well.
Have you tried it out yet?
I ended up purchasing the Ford ABS adapter from RCM for around $90 shipped.. didn't feel like waiting around for another Thexton to pop up on ebay.
This unit is well put together and it works easily enough.. a bit pricier than the Thexton unit, but if you can't find one on Ebay (or someone outbids you) then RCM has a few of the Ford bleeders left.
-Nate
Racer X said:http://cgi.ebay.com/ebaymotors/ws/e...d=1,1&item=4615419116&sspagename=STRK:MEWN:IT
If this was the auction... my bad.I've been working on my sniping skills lately.
I haven't used it yet; I plan to when I do my PBR caliper upgrade, since I'm flushing the system and filling with ATe Superblue.
Now, the adapter you bought, does that connect to a breakout box or does it work standalone? I almost bought that from RCM before I started looking for the Thexton 133, but I was hesitant since I didn't know either way.
n8rsk8r said:so exactly how do these work?:corn:
n8rsk8r said:wow! That is really cool! I may have to pick one of those up also. Is that just for EEC-IV? What is great is I own the 93 sho, 91 mustang, dad has a 87 f150, and a 89 t-bird. Does it work on the obd II? Oh well if not, all our EEC-IV's willl benifit from it! Thanks for the info.![]()
I guess I just wrapped up in the EEC-IV. Actually though that is good, cause I was wondering about my truck 1999 S10. THanks again for the info.SinisterSHO said:Okay, so if I read that right, it pushes all the fluid back into the resivoir. So, how do you prevent that from over flowing? Do you bleed everything out first, then run this, and re-bleed until its empty?
dantheman68 said:yeah, how does it actually flush out the entire system... do you remove the old fluid from the master cylinder and then add the new stuff then run the tool?
how does the fluid in the lines/ABS pump/calipers get out? is that just standard bleeding procedure?
