hydro boost brakes?
32MTX
North Palm Beach
pedal feel like **** too......
some of the mustangs use them I believe, probably wouldn't be too hard to make on a SHO......
Black Bart
maine
thy used them on alot of older lincoln stuff. they are good if you need space or have a heavily modded carborated motor where vaccum is an issue.
1992mtx
Not enough $$$
Ramsey, mn
i am thinking about boosting my car and not sure if i will lose vaccum supply. and if you have the right setup the pedal would be stiffer and less work to stop the vehicle
LJRuddy
Pop lock n drop
Poaceae fields
You plan on using your brakes while WOT? You will still pull vacuum with a boosted engine at idle or on engine deceleration (when you usually use your brakes).
firebat45
Edmonton
I think it would be less trouble to just run a standalone vacuum pump, if that's the concern. Some diesels use them, I think they can be had in electric or belt driven.
1992mtx
Not enough $$$
Ramsey, mn
its just some ideas i have had and playing with im still new to turbos i have played around with my friends cars but still have not completly figured it out
Phoenix
SHOHOLIC
QC , Canada
I got hydroboost on my V10 E450 , and its just another system to do the same job , its changing 4 quarters for a dollar , really.
somedude_001
Western NY
you will still have brakes if you try to use them at WOT for a few pumps of the brake pedal. There is a reserve capacity in the booster. Trust me I did a lot of brake boosting on my turbo ATX. My only issue was melting brake pads and cracking rotors. Never once did I have a issue with my brake booster or the vacume supply to it... unless you count the time I went for a drive and left the line unhooked. That will get your attention in a big hurry.
1992mtx
Not enough $$$
Ramsey, mn
thanks for everyones input it should save me some money on the breaks so i can spend more on the turbo
