How would you fix this exhaust break?
Mike Stitzer
PA
This is the stock exhaust on my 95 MTX. As you can see the pipe broke at the weld to the ******. Is this as simple as having a shop weld it back on or will it just crack and break again there soon? Someone here at work mentioned a ****** repair kit, but I have no clue where to find one. Any ideas short of a new cat back system?
Mike
customperforman
iowa
I would have it welded if it were mine. Then if it breaks again have a new pipe installed.
jbeano
Caledon, Ontario
Common problem. When mine went I took it to Midas. They stocked a replacement ****** with about an 8'' piece of pipe on it. They cut the pipe and welded in the new section. I think it cost me $80 out the door.
GoofSHO
HUGE Dreamer
Vegas
Put in a flat gasket ****** and a flex pipe. That's what I do on all of mine. Eliminating the 'donut' , etc....
Just my .02
B
My '93 did the same thing. NAPA had a 2-2 piece ****** setup that you could put on the pipe. It worked good if tightened down all the way. Cost about $50 IIRC.
Mike Stitzer
PA
Just got a call from the shop and that's the route they went. Cost me 36 bucks total! Thanks for the advice.
MIke
