How would i install a cd player with thse wires?
azmattaz06
Tucson
How in the world would i do this?? Is this one kind'a diffrerent from what you guy's explain to everyone else?
Sorry about the quality it's a cell and it's dark...
jthod
Mr. Goodwrench
Lincoln, Nebraska
You may want to get an amp bypass also, once the aftermarket headunit is in there, it's just dead weight.
Does that kit from crutchfield have the bypass in it?
speedfreek95
Centreville, VA
If you look in the radio opening to the left you should be able to find a second harness the is plugged into a dummy plug(wires go in one side and not the other) that is attached to a bracket. These wires are in there for cars that did not recieve the premium sound system and are wired directly to the speakers instead of going through the amp. Be sure to unplug the amps if you go this route and it may blow the headunit fuse if you do not. Hope that helps
Brendan
Storm-Chaser
Shit Louis
speedfreek95Thank you - I'll check back in a week or so . . . .
azmattaz06 - Matt, another good source for adding aftermarket head units to existing factory harnesses is a company called Metra. Circuit City use to carry them, I'm not sure if they still do. Regardless, they're readily available on the internet and eBay.
