Stanislao
Looking at a '99, no indication that the cams have been welded. I know a number of fabricators in town, but they've almost certainly never done this before. What is the correct method of welding the sprocket to the shaft?
Only information I have so far is from a YouTube video in which the guy tack welds the cams while they're still in the block, turning the engine to get to each point on the cams. That idea scares the crap out of me, as I've seen electronics release the mysterious blue smoke while someone welds on the other end of the weld table. Told him not to leave that motor controller there....
While I'm ripping apart the engine, what else should I deal with? Plugs and injectors come to mind, MAF sensor could probably be cleaned, air filter would get a K&N.
