How to tell if PP or Non-PP?
deltch
Texas
Hi everyone, I'm new to these forums but I stumbled across some threads and youtube videos discussing PTU fluid replacement and tranny fluid replacement.
I was wondering how I could identify whether my car is a PP or a non-PP and what kind of fluids you guys recommend for engine, tranny, PTU?
My SHO currently has 17k miles, purchased used at 13k miles and is a 2017 model.
Thanks
jman1200
Ontario
You are going to get a ton of different answers, everyone believes in what has worked for them and for many different reasons.
In my case:
- Engine: Mobil 1.
- Transmission: Motorcraft Mercon LV. I always use whatever is stated in the manual.
- PTU: Motorcraft SAE 75W-140 Synthetic Rear Axle Lubricant. Pretty expensive stuff.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
What DarthSHO said. You can add a spare tire, you can change your steering wheel, but most people won't change the door sticker.
Look at the white sticker on the door jam and look at the Axle Code.
1A - non-PP
2A - PP
If you have a PI, it'll be something else that is drawing a blank at the moment.
deltch
Texas
https://shoforum.com/index.php?threads/sm105ks-ownership-performance-maintenance-thread.138235/
Everything you need to know is in post one.
For the PTU and RDU Redline Lightweight Shockproof is the best IMO.
I run Castrol Edge with a Motorcraft oil filter.
In my case:
- Engine: Mobil 1.
What are the measurements of amount of fluid it takes for each? Also, filter type? I was actually considering going with NAPA gold on that as far as brands though, thoughts?
P.S. I use mine mostly as a daily driver, but I may or may not decide to cut-loose on a track sometime
All the information is posted in the link.
