Jon Klein
I just ran the codes on my 93 atx and I got a 73, and a 122....73 = insufficiant TP change during dynamic test....and 122 = TPS circuit below minimum voltage...so I popped off the TPS and the white rotating piece inside clicked to its resting spot....which apparently wasn't the same as the resting spot of the Throttle plate. Also, if I used a flathead screw driver I could rotate the sensor past the limits of the throttle...does this mean the sensor is done for? thanks guys..
Jon
p.s. I also got a code 532...cluster control assembly circuit failure...and my CE light doesn't work...don't know how to see if its the bulb either...thanks for all the help....u guys r the coolest...
Jon
