Off Road SHO
Moderator
The problem with having the motor out of the car is not so much being able to keep the crank from turning (I'll describe how later), but more of how to keep the entire motor from rolling around on the garage floor when you use the slow (relatively) method of a breaker bar plus cheater (like SHOAZ stated) versus the fast hits with an impact wrench.
First, stop the crank from rotating. Use a small piece of chain to anchor one of the pressure plate bolts to any place on the cast iron block that is nearby and won't be damaged by the tightening chain. You can even throw a bolt in one of the tranny mount holes and wrap the chain around the bolt.
Second, use a breaker bar and cheater pipe of sufficient length so as to not need a lot of force. If engine is sitting on the garage floor, tie the front of the intake manifold ( the side that would be closest to the radiator) to some immovable object (bumper of another car in gear or park). You can now apply slightly increasing pressure on the cheater bar equipped breaker with a 3/4" or 19mm six point socket attached.
The key is leverage applied to an immovable engine.
Tom
Tom
