How to fix the park mech for the wipers...
Cruez
NC USA
Ok, the wipers work fine.... but they won't park anymore..
How do I fix that??
Its really annoying.. :rolleyes: :mad:
When the control selector is moved to the OFF position, the motor will continue at low speed until the park switch contacts open, signaling the motor to PARK and activating the depressed PARK mechanism which is part of the motor output arm.
There are contacts in the motor that control the park mechanism.
Bizzy
New wiper motor I think is the only fix. Maybe someone out there who can fix it..but I think it'd be more hastle and $$ than it is worth.
Cruez
NC USA
Wonderful.... :rolleyes:
They are working today... We'll see what happens.
Not buying a new motor anytime soon.... :mad:
projectSHO89
SHOless In St L
Go to a junkyard and pull a wiper motor off a donor. Probably will work beter than your current one. Try going for a newer Gen 2.
Steve
89
SHOemup
Dalton, PA
are then are wiper motors off of any other cars that could be used for our cars? I don't know how it is up here, but there arn't many junkyard SHO's around here.
projectSHO89
SHOless In St L
Any Taurus of the same generation will work for the wiper motor.
Remember, except for some suspension changes, the engine and control electronics, and some trim/interior diferences, these things are almost just another Taurus/Sable. Many parts in common.
Steve
SHOMA
Springfield, MA
if they are not parking, the motor is on its way out. Eventually they will stop working altogether, and leave you with wipers aiming at the sky! Good Luck!
Kevin
RStalveyARFF
too many shos
Georgetown, MA
project sho, you are incorrect on the wiper motors. in 94/95 they switched to a single plug on the motor, opposed to the earlier, 2 plug design. This motor is a ford motor though, the explorer, vic, etc all use them. I have however seen a dual plug car converted to the single plug motor. You just need a pin out diagram and the single connector.
projectSHO89
SHOless In St L
sho91mtx,
Thanks for the correction.
How about if i say "get one off the same year after you count the connectors"?? :rolleyes:
Steve
RStalveyARFF
too many shos
Georgetown, MA
He's got a 91, so he has to look for a motor with 2 separate connections. Big deal. They're like 60 bux at autozone with a lifetime warranty.
brianl
Toronto
There is also a module under the dash called something like 'wiper control module'. Few years ago mine wouldn't park. Replaced the switch and motor. No go. Then I found out about the module. Replaced that, and, wipers parked!
It's about 4 x 6 x 1" (from memory..) black, and it's on some sort of bracket that I broke taking it out...
Wish I could tell you more, how to tell 'exactly' if this is bad, etc, but it was the last thing in line...
crystizel
