How to evacuate A/C system aka Scope Creep
ctubutis
Denver Metro Area
So, I picked up a pre-made, 55" negative battery cable w/pigtail from a local NAPA store; also, stopped by my brother's house and picked up an A/C compressor I got from Fred some time ago.
Ac comp battcable
Scope creep 9
Scope creep 4
I have 2 Schrader valves, one in front & one in rear. No A/C recharge kit of my own, I borrowed Fred's:
Scope creep 7
Scope creep 8
Question: I can't find a Schrader valve on this existing setup, so how can I empty the refrigerant? I have no idea if there is any actual charge remaining, but there very well could be.
Irish Pride
Irish Inside
MusicCityUSA
This entire piece is the valve. There isn't a serviceable schrader valve. Take a wrench and turn it off the line.
20210617 212727
SHOrod
Torrie Tuned
Cedar Rapids, IA
That compressor you picked up appears to be missing the clutch, so if you plan to install that compressor on your car, make sure to install the clutch before you connect it to the car. Looks like it would be a real pain to try to install with the compressor mounted in the car.
-Rod
Irish Pride
Irish Inside
MusicCityUSA
-Rod
It's very doable. Getting the nut loose to try and remove the clutch is a pain. Just installing the clutch isn't bad at all.
-Chad
bmytych
