How thick is the sub-frame?
Moneypit
Houston Texas
How thick is the sub-frame where the rear SFB's go? I'm needing this to know how big of a shim i'm going to need for the aluminum bushings i'm going to put on... :huh:
Bizzy
you really don't need a shim. There are 100's of cars out there without any shims in there and they are all fine. That said, also adding a shim can put the nose of the bushing via the shim in contact with the body of the car, which is not the way they are designed. The gap is there to allow for a gap to put both halves of the bushing in compression to hold the SF pinched between the halves.
