How many miles from EcoBoost motor
lawyerdement
TN
I have a 2010 SHO with approximately 164K miles. When I purchased the car it had approximately 39K miles. I change the oil regularly and drive fairly conservative most of the time.
Here is my question: what is the life expectancy for this motor under these circumstances? What major complications, if any, could I expect in the future?
Turbos and water pump should be your concerns.
I agree. At that mileage you should consider a water pump replacement. If those fail internally you can have a real problem. Just something to think about if you consider prev maint. at higher mileage. I don't know if there is enough of a high mileage average for when to expect issues. The early production for this incarnation of the cars are just starting to get there now. Consider yourself a pioneer.
That was well put.
FiveLeeter918
Ortiz Performance Sales
Tulsa, OK
agreed. Timing chain and water pump need to happen soon if they haven't already, other than that the engines are pretty bullet proof in stockish form.
I have seen turbos go as soon as not much over 100k miles on examples that were not well cared for. I have seen well cared for examples at nearly 200k with original turbos.
The advice above about water pump and timing chain is spot on, imho.
