How do you change the EATC
oldshoman
ny
All my heater control buttons shot on my 94ATX. I have a replacement EATC but am clueless as to how to pull the old one out. Can someone give me a step by step
TYSHO
Earth
-Pull the cover under the steering wheel off, held by 4 bolts/screws [torq]
-Remove headlight switch **** and nut behind it [3/4" nut]
-Remove all bezel screws [7mm if i recall] and pull it back, disconnecting all electrical switches then pull the entire thing off
-Remove the 4 screws [7mm if i recall] holding the EATC in place, then pull out
-Disconnect the two electrical connectors from back of EATC
-Remove the two 10mm nuts holding the vacuum lines on
-Install in reverse
