how do i get my keyless entry code
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
Look on the underside of the trunklid...or in your owners manual...on the in the glovebox I believe...and it should be on the black box in the trunk drivers side, near the floor of the trunk mounted to the back seat.
Total of 4 places...or open the box and there is a way to read it off the wiring... :thumb:
KyngofPop
Freday-day
Charlotte NC
If I am also correct it should also be on a label on the side of the ECU mounted behind the glovebox.
BCSHO
Georgia
sometimes it is on the arm that supports the decklid. It is a little white sticker with 5 numbers on it. That's where mine was.
5.0 5speed
gotta love ford
revere
thanks i found it it was right in the trunk clear as day thanks
