How do I empty the Freon from my a/c compressor?
BBoiByron
Salt Lake City, Utah
I'm trying to take the a/c compressor out of my '90... My friend told me I need a special tool to empty the freon out of it, can I buy that in local stores? what's it called? how much do they run?
thanks in advance
Mels
SHOVELHEAD
Brookfield CT
Well, you should do it the lawful way... which is to bring the car to a federally certified recovery / recycle tech., most shops and garages have 'em. There the refrigerant will be removed from your system properly, but at a fee.
If you are removing your A/C compressor, it is probably because the A/C system is not working. I'll bet there isn't much, if any, refrigerant in the system. Remove the low or high pressure tap cap and press the pintle for a split second. If you don't get a blast of frostbite-creating discharge on your hand (read: caution), there isn't any refrigerant to remove. It's already gone.
