How do I change side marker lamp?
kcobra
Maine
Do I have to pull out the inner fenderwell, or do I have to remove the whole front clip? Thanks. Whatever the case, seems stupid as **** and complicated for nothing.
cheech
Pa
Inner fender well is how do it. Its still a tight squeeze Just unscrew the front portion to access
kcobra
Maine
Thanks. Car is still covered under bumper to bumper, is this light covered?
kgupton123456
Tacoma, Washington
when I am replacing the headlighs with my self modafied headlighs, I think it will be easer to take the from bumper off. it takes 5 mins to take off the bumper, all that you have to do is takethe 5ive plastic screws off the bottom, the 2 on the bottom wheel fender (inner outer), and the four 10mm bolts on the top plastic the holds the grill. then you can change both lights in the headlights
crystizel
