Here you go :
The first two are Pat McGrath's righteous 91 Vortech'd car.
The third is my last dyno with the SHO.
Pat can fill us in on the specifics, but I believe he was @ 12psi on the first one, and @ 15psi on the 2nd, with race gas. All this on a stock compression 3.0, right Pat?
Mine was @ about 13psi on pump gas on a lowered CR 3.2. Keep in mind my added displacement will complement my TQ numbers, and Pat's higher compression will help his HP numbers accordingly.
Here is how I read the charts.
1) Peaks -
385hp @
7000rpm -
308ft lbs @
6000rpm
Torque curve - over
275ft lbs from
4700-7200rpm
@3500rpm - 160hp, 230ft lbs
@4000rpm - 180hp, 240ft lbs
@4500rpm - 225hp, 265ft lbs
@5000rpm - 275hp, 287ft lbs
@5500rpm - 310hp, 300ft lbs
@6000rpm - 350hp,
308ft lbs
@6500rpm - 370hp, 295ft lbs
@7000rpm -
385hp, 285ft lbs
2) Peaks -
445hp @
7450rpm -
325ft lbs @
6250rpm
Torque curve - over
275ft lbs from
4700-7400rpm
@3500rpm - 155hp, 225ft lbs
@4500rpm - 215hp, 265ft lbs
@5000rpm - 260hp, 285ft lbs
@5500rpm - 310hp, 305ft lbs
@6000rpm - 360hp, 320ft lbs
@6500rpm - 400hp,
325ft lbs
@7000rpm - 435hp, 320ft lbs
445hp @
7450rpm
3) Peaks -
430hp @
5900rpm -
412ft lbs @
4850rpm
Torque curve - over
350ft lbs from
4150-6300rpm - over
310ft lbs from
3900-6800rpm
@3500rpm - 155hp, 230ft lbs
@4000rpm - 240hp, 320ft lbs
@4500rpm - 340hp, 400ft lbs
412ft lb peak @
3850rpm
@5000rpm - 380hp, 405ft lbs
@5500rpm - 400hp, 380ft lbs
430hp peak @
5900rpm
@6000rpm - 420hp, 370ft lbs
@6500rpm - 405hp, 325ft lbs
@6800rpm - 405hp, 310ft lbs
