I had this problem on my red 94 from time to time.
If you experience this symptom, try cycling the key on for 4 seconds, then off, then on for 4 seconds again, and repeat this 4-5 times. If that solves your problem, you have one of the following issues:
bad fuel pump checkvalve, allowing pressure to bleed down,
bad injector, not shutting off completely, allowing pressure to bleed down,
bad gas, vaporizing in intake on hot soak.
If that does not solve your problem, then you have a spark issue, which could be any of the following:
sick crank sensor (as suggested above)
sick dis, failing during heat soak
sick coil, failing during heat soak (not likely that all 3 will fail at the same situation)
other electrical issue.
Hope that helps you narrow it down.
