centaurus3200
went to work today and upon pulling into the parking space, i noticed a horrendous rattling coming from the engine bay.
i opened the hood and it's definitely coming from around the water pump. sent the car down on a flatbed to nick chrimes. when nick got the car, he took a listen and examined the water pump in a cursory sort of way. he said it's probably not the water pump. could be a busted timing belt tensioner or ????
the water pump does not leak any coolant.
the car was idling smooth. if not for the sound, you would be none the wiser.
i don't think it's the rod bearings as i had them replaced about 35,000 miles ago. the sound is NOT a knock but a "rattling and gurgling" sorta of sound. like something is loose. it coming from around the water pump pulley which would lead me to believe it's tensioner, water pump, timing belt issues. what else is around there that would cause this?
anybody have any ideas? nick will tear into it on Monday, just curious to see what you guys think.
thanks,
Robby
thanks,
Robby
