Black Stallion
Ok so here is the brakedown. My car is currently in the garage. I told him to put new pad/rotors on my car. Then take a look at my "hard shifting (I posted back a little time ago that it is hard to shift) I drove the car to the shop perfect, shifted perfectly. OK, so I guess he took if for a ride. Then he calles me and tells me that he can adjust it fine, but if you happen to let go of the clutch all of a sudden it will loosen back up. He can not keep it tightened. Now some of you guys told me to adjust it using that blue quadrent. Well I didnt get a chance to do that, but I told my mechanic that there is a spring on the back of the blue quadrent that might be shot. He said yes that is true but if you would replace that you would need to get a whole clutch pedal assembly, is this true? First he told me that it wasnt the transmission, so I dont have to worry about that. But now my dad stoped in (cuz hes do ******** nosey) my mechanic told him that he might have to pull the tranny out. Any Ideas.
