highly recommended
philw349
PhilW
Tucson, AZ
I didn't really think adjusting the clutch pedal would do much for shifting. All this time I figured this was as good as it gets, occasional reverse grinds and all. But one day I put my foot under it and pressed it up just like you're supposed to, and I couldn't believe how much nicer it was. It was so easy to move between the gears and reverse felt like it was actually "there" after that. I highly recommend this. Also if you are having bumpy shifting check the TPS it was bad on mine and caused tons of oscillating between shifts. You can get it checked at Autozone to see if its good. SDPatt gave a good tipoff on that one.
