ghostrider
I have noticed recently that upon startup, when the car is hot or cold, there is a high pitched squeal that comes from the pulley side of the motor. It's a 91. I've done a little reading and have heard that it could be a belt, or to much tension on the belts. Now I don't believe it is any of the accessory belts being old and slipping, because the belts were changed about 20,000 miles ago. I don't know about the tension though, since I didn't change them myself. Probably not tension either because it just started doing this. I've also read that it a bearing in one of the pulleys, or maybe even the timing belt. The squeal doesn't happen all the time. And I don't know how to make it happen. Any idea on how to figure out where the the sound would be coming from. Or what to look for.
Sorry so long. Later
