High compression pistons
zach44102
BIG TURBO
Georgia
Im looking at going high compression over the winter. I spent some time on the phone with Wiseco and got some good answers and quotes. My plan on is going with a 12:1 compression motor with a 93mm bore.
My questions is do you think for street duty will I be able to run 93 octane? If pre ignition happens can the knock sensor compensate for the higher compression? I know most of the HC guys are going 10.5-6:1 and running 93 with no problem.
What was deaconblue's custom built motor running? I'd shoot him a pm and talk to Josh at shonut.
jayro
Auburn, In
Your cams are going to help you some since they reduce your cranking compression, but I don't know if it would be enough. I know the knock sensor's ability to pull timing can be increased with an LPM. Beyond that I don't know if you would need to fiddle with the stock timing curve to keep detonation from happening.
Were you planning on doing some custom tuning to it?
zach44102
BIG TURBO
Georgia
Well I plan on running a twEECer. Im pretty confident from my research I should have no problem with 12:1 on 93. It will definitely not be the recipe for power but it will work. The power will be made when I throw some race gas in there so I can take advantage of the compression. I know with the tweecer I can pull timing to prevent preignition so I gueess that will be the plan. I guess I will have to find out the hard way since I only know of 2-3 motors running that kind of compression.
