hesitation
poissonverte
iowa city, ia
Doesnt happen all the time.. Hit the gas hard but not WOT from a slow rolling start and it doesnt kick in right away, almost bogs down then it REALLY kicks in.. no codes, no other problems.. Im guessing Plug wires, but i dont like to spend money w/out a second opinion. wires have 126K on them
93 ATX
124K
MODS: 4 slicers, 2 stickers, license plate, fog lights, moonroof, cd player, rear spoiler.
Next MODS:
Sitting in their respective box
DougLee25
Hatboro
Check your plug wells for oil. This could cause a hesitation. You may want to replace your plugs, wires, and intake seals if you have oil in your wells. Just make sure you get out all the old oil in the wells before you take the plugs out.
Doug
ryana83
Nashville, TN , USA
I had the same problem with my car. I replaced the fuel pump with a Walbro and the hesitation went away. I'm not sure if that will fix your problem but it worked for me.
Some other things to check would be the TPS and maybe see if the throttle cable is frayed anywhere.
Ryan
91 Black SHO+
Police Grill, SS Cold Air, Pulleys, Walbro 155 LPH fuel pump, Removed Silencer Cone, Ravin Mufflers, Weight Reduction
N
NothernSHO
Guest
My 94 ATX does the exact same thing. It has been really bothering me. Of course I just went and saw my mechanic and it didn't do it and then as soon as I left the garage I got it to do it. Does your car also have problems starting sometimes? I find that sometimes it doesn't want to start the first time I try but then the second time it always starts up. I also just replaced my plug wires and my plugs and its still doing it. Any thoughts on how to fix this problem would be greatly appreciated!!!
poissonverte
iowa city, ia
I was leaning towards wires or fuel pump.. since the partial 60k stuff was done.. umm anyone know of a good place to buy a 190lph fuel pump??
93 ATX
124K
Next MODS:
It could also be a poor signal from the throttle position sensor. A fluctuating signal can cause the hesitation and not set a code. This TPS condition can make the engine feel like there was no accelerator pump (for those that remember carburetors) and not pick up rpm quickly with a fast throttle opening.
Scott
1991, 254K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
6 disc CD, Class II hitch, Silver award at SHOklahoma Car Show
D
WOONSOCKET,RI,USA
if the tps was out of spec,it would all so cause hard start on cold days.
[This message has been edited by D (edited 01-22-2002).]
poissonverte
iowa city, ia
And the world turns.. the CE light did blink and gave me the TPS sensor "overflow" but now its fine no codes.... So i decided not to change it.. guess ill have to..
93 ATX
124K
Next MODS:
