Hesitation/Bogging...
SASHO91
Zoom Zoom
San Antonio,TX
I've delt with this for long enough....
problem:
@ highway speeds anywhere from 60-75 in 5th gear, if i go 1/2 to 3/4 throttle, to say pass someone, i get a mometary bog of the motor, it only happens for a split second.... and it does that 4-5 times before stopping and pulling normally.... almost like a studder....
It has been an issue for awhile now, but really hasnt bothered me to bad... but tonight i had the last of it... it gets really annoying.... let alone i dought it is good for the motor.... Also A/F goes crazy when this is happening, but i think that is just an after effect of what is happening though.
I have been told that it was the IAC or IAB valve whichever you prefer....
and i have also heard of it being the TPS sensor...
I have cleaned the IAC/IABV to no avail.... however i have yet to swap in a new TPS...
I know this has been disscused before, but for some reason i couldnt find that thread... maybe i was using the wrong search words... :shrug:
A point in the right direction and i would be much abliged....
TIA.
laxmax327
philly
tps could def be culprit. no codes? maybe plugs or wires, but my moneys on the tps. check for codes though first. that could solve it. might still need replacing either way though.
AREA 91
PA SHO SHOP
Area 91
I used a DVOM to test my TPS. I slowly moved the throttle from idle to WOT, with the key on engine not rinning. I found a "flat spot" where I could move the throttle a little bit, and the voltage didn't change. Replaced the TPS with the Windstar verson, and all is well. :thumb:
SASHO91
Zoom Zoom
San Antonio,TX
I forgot about doing that.... thanks for the tip...
i'll probably pick one up today anyways... :thumb:
Edit: Im not sure i remember the right wire... its the top one correct? and then just to ground??
fred79
pittsburgh
could your clutch be starting to go? see if it slips at a certain rpm range mine is going and slips around 2500-3000 if i let off and give it gas slowly power comes back.
Racer X
SHO Pilot, Retired
Connecticut
Why the Windstar version? Increased reliabilty or something?
Rockledge
Pluggin' away
Connecticut
FWIW, the Windstar TPS has the same base part # as the SHO (9B989). That particular TPS is shared across many applications, in fact.
Regarding the bogging @ 1/2 to 3/4 throttle, has there been a fuel pressure check done? What's the status of the fuel filter? Also, have you tried cleaning the MAF?
SASHO91
Zoom Zoom
San Antonio,TX
fuel filter has a few K's on it...
Fuel pressure was fine the last time i checked... a few months ago.... but i will check again....
The maf was just cleaned... did not use carb cleaner.. used the right stuff....
could low octane fuel cause this?? before the W/P went out i ran some 93 in her... and i cant recall it bogging.... i could be wrong though...
