MilTownSHO
My anti-lock light on my new 92 will occasionally come on but if the car is restarted it will go off. The brakes feel fine to me, although one or twice the ABS has kicked in while coming to a stop while moving at very slow speeds. I pulled the codes today. I got:
22 IFL Reference Voltage Out Of Range
24 RH Front Inlet Valve Fault
44 LH Rear Sensor Fault
43 RH Rear Sensor Fault
53 RH Rear Outlet Valve or Circuit
57 RH Rear Sensor Fault
63 Pump Motor Speed Sensor
So, basically I'm thinking this is going to be tons of $$$ headbang
Any advice?! shrug
Any advice?! shrug
