Help with Driveline/Susp rebuild.
93rev2sev
Hockeytown
Had my tranny rebuilt by Bizzy.
Bought new subframe bushings, New axles, New control arms and new strut rod bushings.
Need to know the following torque specs.
Axle nut - 30MM locknut.
Subframe bushing bolts - 4 new gen3 bushings and 2 new recall kits.
It seems like the drivers LCA is too short but I have not yet torqued down the axle nut...so I'm hoping that once the nut is torqued, it will draw the spindle in far enough for the LCA to fit. I tightened it as much as I could with my 1/2" craftsman and one arm but I'm sure its still got a ways to go. Once the axle nut starts to tighten, how much farther does it have to go? It seems like the LCA is about 3/4" short...could the axle nut still need that much turning?
93rev2sev
Hockeytown
Thanks sasho...I thought that was right but was unsure with the gen3 bushings.
CerberuS
300 HP N/A SHO
Granby, QC, Canada
Used to torque knuckle bolts with a 1/2 impact gun full power , at my place.
Your not gonna break anything not torking these. Ppl seams to torque everything these days its unreal.
Torking in a real garage hppens only when working on engine or tranny internals (head bolts , cam bolts - etc.)
Axle nut (Hub retainer) - 30MM locknut. -> 180-200 lb-ft
Subframe bushing bolts - 4 new gen3 bushings and 2 new recall kits. -> 70-85 lb-ft IIRC
