Help with CAM position sensor....
S
SHODOG220
Guest
Where is the Camshaft position sensor located and how do I replace it? My Black SHO is stuttering like crazy and before I go spending a billion dollars on a 60k, Id like to replace the Cam sensor since Ive heard that its not as hard as some other things.
92 black/black MTX, 48k miles, SHO SHOP Y-pipe, Ted B. LPM, 80MM MAF,HUGE K&N cone filter, silencer box removed.
91 White/Black MTX: Dynomax catback/Summit Turbos, K&N Filter, Boxless, Kuhmo ECSTA 225/55VR16 tires, Centerforce Dual Friction Clutch/Grizzly TOB, SHO NUT Motor mounts. SHOCAGO Member
http://www.picturetrail.com/shodogg
cam sensor is located below the intake on the back passenger side. looks kind of circular w/wires coming out. check out a haynes or chiltons to get a better visual.
The cylinder identifcation (cam) sensor is located just to the left of center in the photo below. There are two 5.5mm (7/32") bolts that hold it on the rear bank exhaust camshaft.
Scott
