help with a leak
haunter
CA
So a few weeks ago after a big storm, I was greeted with a small pool in the passenger front floorboard.
I went ahead and removed the front cowl and cleaned those drains, and the passenger side one was very full of leaves and dirt ETC.
2 more rains, nada.
Big storm last night, and lots of water again :(
I see some water trail that indicates it is coming down the A-pillar and exiting where that meets the dash.
I am guessing sunroof related?
haunter
CA
IE I already did this:
haunter
CA
cleaning the cowl drains out, sorry, I meant to link a specific post in that thread and it didnt work
ok so the other things to check-- as you mentioned sunroof drains, door drains clogged, potential windshield seal leak. Also potential that maybe putting it back together from the last clean -- maybe there is a small gap or leak with that. Do the easy/likely first. sunroof and door bottom. test a little and if needed go back into the mess you played with last time. test again etc. I've seen more strange leaks places but not on this model of car so far.
haunter
CA
front sunroof drains were not flowing at all, they are now!
fingers crossed this does it. was definitely dumping water right into the ceiling of the car
mission bc canada
my driver side drain plugged in the summer - last week pass side - tried wire - nope some weed wacker line - - nope - so a few squirts of air - not full blast - then it drained out at lower wheel splashshield -
haunter
CA
anyone know where to get a replacement for that stupid plastic clip in the center of the windshield wiper cowl?? mine disitegrated when I was removing it
J Mack
Michigan
Did you clean the sunroof drains? The hoses that are in the pillar.
Could somebody please point out where the drains are within the sunroof? I want to unclog them (water builds up on corners of sunroof) but I can't find any drain holes. Thanks.
J Mack
Michigan
Diagram here. Look at teh corners where the drain hoses attach. The holes drain to there
not sure if this will help but interesting
mission bc canada
the holes are there- must be "mudded" over - just because s/roof is closed it still lets water in- that's why the drains are there - as i mentioned in my Jan/23 post try a squirt of air - - pour some water in the gasketed area and look down on ground near splashield - should drip out - maybe exit of drain is plugged up with road debris - wiggle the splashield around - blow air in behind - worked for me - and check the oval drains at btm of doors - they'll plug and you can get water filling up in door - my rear pass door did that -that lower seal sits tight to the btm edge of door - inhibits drains doing their job.
thatSHOguy101
