HELP w/CLUTCH
xpnsiv93
Corrupt state, IL
WELL, i got the new clutchmasters clutch pak put in!!!!..new fork bushings, etc: SO the issue is now that it's all installed there is NO clutch, well it's there but barely, we tried adjustment..NUTTIN...u let out on clutch give gas, car barely goes, WE KNOW that everything went in as it should have, but yet it feels as if theres NO PRESSURE and no power transfer from trans. to engine, someone(s) please help in shooting suggestions my way, i dont wanna have to see this trans. come out again!!! ALL HELP APPRECIATED
-nick-
xpnsiv93
Corrupt state, IL
well when u push the pedal in, the fork lever moves, but if u try doin the pulling up on the pedal adjustment, there is no clicking, could that be a sign of a faulty something? we pushed it over and over again w/no avail.?!! it builds no pressure!?!?!
Racer X
SHO Pilot, Retired
Connecticut
You didn't do something silly like install the Pressure Plate 180* out of phase, which would causing the locating pins to space the pressure plate instead of... well... locate, did you? :shrug:
Just a thought...
SASHO91
Zoom Zoom
San Antonio,TX
Loacating pins? can you explain this to me..... I just installed mine as well.... im not sure if i did it right..... i dont want to get the trans back in to find this out.....
Mr Anonymous
Tire Wall
Unfortunatley, this is becoming a more frequent problem with the Clutchmasters kits. IIRC, the remanufactured pressure plate included in your kit is out of spec. Hopefully Fred will chime in here with more details since he has first-hand experience with it. You could also try searching the forum for "clutchmasters" as I seem to recall a few discussions about this.
In any case, it will need to come out again. Sorry.
Mike Kopstain
Arlington Heights, IL
What problem is this Chris? We've sold hundreds of these kits and have not had a single complaint as of yet installation or otherwise. Are people putting them in wrong?
Mr Anonymous
Tire Wall
Mike, I can't specifically recall the exact problem but vaguely seem to remember it being a problem with pressure plates. Fred had at least one, and maybe two, that after install went nowhere. There was another mentioned on either the forum or one of the email lists about a week or so ago, and I seem to recall at least two or three occasions in the past year, plus this one. All had the same symptoms: brand new CM clutch installed (OE equiv.) but no power to the wheels.
Again, I'm hoping Fred will chime in here and prove I'm not hallucinating (anymore).
ViPER1313
Ijamsville, MD
Did you wipe the oil off of the pressure plate and flywheel with laquer thinner before you put it all together?
