help shifting is making the car jolt
89_SHO
Miramar, FL
Whats goign on guys. I was on my way to a friends house to get a lift , and decided to take the sho out for a few. Went to drive it , and when ever i shifted the car will jolt ,and buck, and boggled, all the way up to 3rd. Held the cluth in semi to settle the bucking a little till i got home. During all this the rpm guage also stop working? Then out of nowhere it stopped , and shifted fine all the way home. Does this sound familiar to someone? any info please?What should i do? Thanks in advance
Gez89SHO
LEGO SHO
NE Philadelphia, PA
Check your coil pack- mine did this and it felt like you describe. When I looked at the coil, I found liquid (water condensate I guess) in where the coil wires plug in. Cleaned them up and it was back to smooth.
89_SHO
Miramar, FL
Ahh ok thanks alot guys im going to just take the motor apart ,and rebuild it. i learned something cps is crank postion sensor
masho95
got Zex?
Chicopee, MA
CMP - Camshaft Position Sensor
CKP - Crankshaft Position Sensor
You have a bad CMP.
