Help Please!!!!
randy'sho
95 White MTX
High Point, NC
guys i have coolant leaking from a strange place....about a foot from the passenger side tire towards the shifter in the car....we have like 4 or 5 plastic line that run down the passenger side of the car and where those turn from the engine to the underbody there are like four or five holes in the undercarriage(just above these lines) of our cars and i have coolant coming from those holes...what the crap you can't see in there to see where it's coming from .....please help a man out!!!!
ohfosho
ontario SHOwner
ontario, canada
waterpump maybe leaking down the lower rad hose a bit, or it's the lower rad hose...they should be replaced every so often...
if its more in the back of the engine bay, then it is more than likely a line to the heatercore, or the core itself
randy'sho
95 White MTX
High Point, NC
yeah guys i think that it's the heater core.....because there is a line that enters the car directly behind the engine about two feet down from the top of the intake and there is some other fitting below that and there is coolant that drips from that plastic fitting.....i can smell antifreeze when i run my heat....how hard is it to fix your heater core (does this sound like the heater core to you guys?) any estimate on price to replace or install?
thecrew2999
3.2 MTX SHO
Harrisburg/WilliamsportPA
if you can smell it when the heats on then you need to change the core (job you dont wanan think about) and if its just a line its simple
the heater core you need to remove the dash. ive swapped my dash it takes me little less then 4 hours now but still a lot of work and your first time it takes all day
randy'sho
95 White MTX
High Point, NC
yeah i am sick of dealing with this thing nickel and diming me to death....i just got it back from getting a y-pipe installed and new resonator......i might just bypass it to get by for a month or so to ease the pain!!!
