Jason N
Hello. I am in need of help. I am not mechanical, at all so excuse the ignorance.
I have the lms corsa cat back exhaust with thunderstorm dp and high flow cats. I moved back to NYS and need to out the oem cats back on to pass inspection. Can only get 2 monitors not ready so it won't pass. Evap monitor won't come on and cat monitor throws the code of course.
My question is I took it to a chain muffler shop and they said I can't put the stock oem back on because there's no ******. I am not mechanical but I've been told numerous times this should be able to be done and they can't weld because the exhaust is stainless.
Any guidance or walk through or guidance that I could show a mechanic would be appreciated.
Thank you
Thank you
