Help please kind people
Logix
Longview
You all have helped me in the past so here i am to try again. I have a 95 sho and suddenly one day my interior lights decided they won't go off while the car is running and even when i shut the car off it takes a long time for them to go off i've even set the autolamp to off and it still does this. also the car no longer automatically locks itself when i put it in gear. and its all the interior lights that are on as well as the lights around the door key hole and keyless entry. any ideas? i've tried unplugging the battery to see if anything would reset and we looked at the fuse to see if that would be it and all of them looked fine but if there is a fuse that controls all that let me know and i'll try changing it anyways.
any help on this would be nice.
thanks
Belvis
shopartsnw
SHO Medic
Sponsoring Vendor
Battle Ground, WA
Just a guess, but I think maybe a door switch might be bad. That would make the car think the door is open so the lights won't go out. Also, if the door is open, I don't think it will autolock. Start with the driver door switch.
Are you in Longview, WA? Or is it another Longview?
Good Luck.
- Mike
Logix
Longview
Longview texas, i'm going to try some **** on the switch first to see if that will get it.
poffffd
