Diameg
I went for a drive yesterday (for about 10 minutes), and when I got back I popped the hood to mess with some stuff. I undid the battery and noticed that I did not back the car up enough to get the garage door closed. So I pushed it back. Then I noticed I was standing on several wet spots. I could tell right away that it's coolant, so I checked to see if any hoses had come loose or anything like that.
There are no hoses that I can see that it's coming from.
I have ruled out the upper and lower rad hoses, and the drain ****.
The coolant drips from the frame right below the rad itself, it drips from several spots along that frame since it is running along that.
Overnight when the car was not running, it was a very slow drip, probably around 1/8 of a cup the entire night.
When I start the car and let it run, it gradually picks up until it is pretty well pouring down.
Looking under the car, I can see fresh coolant right where the side tanks of the rad meet the grill part.
Do I need a new rad or by some stroke of luck could it be something else?
Thank you.
Thank you.
