well, I bought a well used 1993 SHO with 153K miles a few days ago. But its got a few problems, currently at idle and normal operating temp. the oil pressure light flickers. I was wondering if it would be ok to use a different weight oil (ie 10W-40) to thicken it up and up the oil pressure? I also managed to blow out both rear brake lines at the same time (on a hill with a stop sign at the bottom no less) which rendered that dual safety system pretty worthless. Do I really need that stupid Rotunda brake bleeder? Any ideas on the price of CV joints too? and finally, any of you ever experienced 5 dying panic pings while unhooking part of the harness near the master cylinder (note..now the temp and fuel needle are pointed straight up) I hope I didnt fry it :-(
anything helps! Thanks!
Regards,
Tim
Regards,
Tim
