BiyatchX
94 MTX
I just replaced the following items, and am getting no spark now. The tach moves to 3-500 while cranking, and it ran when I pulled it into my garage. The 3 timing marks line up perfectly, CPS gap @ .030, ground strap hooked up and tight, crossover bolted down. I have read every post I can find on the forum for no spark and have tried most suggestions. Any help would be greatly appreciated.
Replaced:
Clutch / TOB
Rear Main Seal
Rear Main Carrier Gasket
Oil Pan Seals
Front Main Seal
Water Pump
Timing Belt
CPS
Spark Plugs
Valve Cover Gaskets
Thermostat
Thanks,
Ben
<small>[ July 11, 2002, 12:48 PM: Message edited by: BiyatchX ]</small>
Replaced:
Clutch / TOB
Rear Main Seal
Oil Pan Seals
Front Main Seal
Water Pump
Timing Belt
CPS
Spark Plugs
Valve Cover Gaskets
Thermostat
Thanks,
Ben
