Help needed with fuel pump and relay module
RaSMG
CA
So my SHO wouldn't start the other night, no fuel pressure at the valve on the manifold. it has done this a few times before and we have checked the switch and everything but then a day later it will work, we came to the conclusion that the pump is cutting in and out and it's on it's last leg. So we found the pink/black wire from the switch/relay to the front relay module and tested the voltage. We think the bad fuel pump messed up the old control box/module and fried something cause it's not sending any voltage to the fuel pump. We bypassed it and supplied a 12v source and got it to work but then it wouldn't later so it's definitely the pump cutting in/out. So my smartass dad goes to the junkyard and buys a relay control module out of a 94 Taurus. Plugged it in and it worked, so we can now put in the new fuel pump theoretically without having a burnt out box. The problem is that the 'new' box has a different part # than the old box. My old box was F1DF-XXXXXXXX and the new one is F3DF-XXXXXXX, everything is the same except for the F1/F3 which just means 91/93. Is there a difference between a 94 taurus relay module and a 93 SHO relay module? Oh and where should I get the fuel pump for cheap cause kragens wants like $100. Thanks!
Mr Anonymous
Tire Wall
Is the big letter on both CCRM's the same? If so, you should be fine (the fact that it runs tells me it's fine...). :)
RaSMG
CA
so anyone know a good source for a new fuel pump?
