help.. my car sucks
froggyknh
iowa
I have a 93 ATX. I have had nothing but problems since day 1. Right now, the idle is screwed up. Sometimes when in park, or in gear and stopped, the idle drops to 500 RPM or less, and ocasionally dies. I reset the idle (unhooking negative battery cable, etc) and now it doesn't die as often, but after I have been driving a few minutes, the idle goes up to 1600 RPM when i stop, and up up to 3000 RPM when iI put it in park after driving appx 10 minutes. It still idles low when I first start it too. It also gets crappy gas mileage. (14-16MPG)
I had a mechanic friend check for codes and came up with nothing. He said it sparks great, and doesn't think its a cylinder misfire. He is completly baffled. I have replaced tons of parts and I am sick of putting money into it, and nothing fixing it.
I have replaced:
valve cover gaskets and tube seals
intake gaskets
plugs (twice)
wires
EGR valve
DPFE (map sensor?)
IAC motor
Throttle position sensor
Mass air sensor
timing belt
fuel filter
If anyone has any other suggestions, that would be great. I love the car, but I am about ready to give up
whiteman_01
Well-Known Member
Hastings, MN
I would first off try resetting the idle again. Only this time you want to load the motor right after you start it.
Within 10 seconds you want, AC on max, headlights on, shifter in drive, and turn the wheel side to side.
93rev2sev
Hockeytown
The only thing I would add to your list is o2 sensors and vacuum lines.
(pssst: vacuum lines)
froggyknh
iowa
yep, knew I'd forget something. O2 sensors have been replaced, and vacuum lines have been checked, and broken/cracked lines replaced.
froggyknh
iowa
I have also:
replaced head gaskets
cooling system flush
tranny rebuilt
new intake coupler hoses
froggyknh
iowa
was rebuilt less than a year ago. Why would the tranny mess up the idle?
Endri_SHO
SE 300 , S 500
IN THE MERCEDES-WORLD
the only thing that might be fixing your problem, is vss ( vehicle speed sensor) replace that and reset the idle again.. tell us what happens.. i had the same issue in my 93 atx and after e new vss was installed the issue was gone...
good luck
endri
froggyknh
iowa
Great. I'll have to do that. I bought a new speed sensor a few months ago, because of some downshifting problems, but never put it in cuz it looks like it's going to be a pain to change (and the one on the car was not plugged in, unsure why) After we plugged it back in, it quit having the downshifting problems, so I wasn't so concerned about replacing it right away. (was gonna wait till we did the power steering rack). But we will change the speed sensor and see what happens.
froggyknh
iowa
Well..... was driving on the interstate today.... when I got off, my car died on the ramp....seemed reluctant to start back up, but it did.... now has a horrible upper end knock, with a bit of a squeak...... pulled over immediatly and had it towed home.
Also, the past few days I noticed my oil light coming on when I stopped, but it went off as soon as I gave it some gas or started going again. Checked the oil, and it was full.
So now it sits till we figure this one out...
bmytych
