HELP motor bounce
THEREALSHO16
RED MTX 95 SHO
SPring, tx
today im driving along and i notice that every time i press the gas the stick from the transmission moves back and then when i push in the clutch i feel the engine slam back down
im figuring a broken motor mount
any ideas
and how much it would cost to fix a motor mount
also my car sounds really different 9 like a ricer when i have a stock exhaust) and is idling wierd all of a sudden too
THEREALSHO16
RED MTX 95 SHO
SPring, tx
well i did some research and it seems to be the front motor mount
does any body know wut kind of aftermarket mount i could get
ford is way to expensive
jedhead
westminster,ca
I would get one of the mounts that Josh strengthens.
Click on the SHONut ad at the top of the page.
Bob
1993MTXSHO
Its a Taurus...
Jersey
if your stock and dont plan on upgrading just go with a stock mount although they are known to fail but they will be a lot cheaper used. also you probably messed the exhaust up because the engine was twisting and you losened something or cracked a manifold. jsut start the car and feel for leaks around the pipes but you might be able to hear it as well if its bad.:thumb:
AREA 91
PA SHO SHOP
Area 91
The SHO NUT EXTREME MMT's are the way to go if you don't want to EVER change them again. I've had the same ones for 5 years in my daily driver, compared to my buddy who has changed his twice! Gotta pay to play.
bmytych
