HELP ME!!!!
SHO SPD
SHO member #480
Naples, Florida
MY car is rock solid in the back, I cannot move the rear suspension at all, are my struts bad, or is it my shocks? If I were to jack up my car right now, the wheels would not drop even a mm. they are all the way compressed, and will not lift or anything, the only suspension I have in the back is the rubber on the tires, and that is a VERY hard ride, I get out with a headache. any help?
1989 Titanium pearl
CAI
K&N cone filter
Slicers (thanx to G/F)
JBL speakers (thanks Adam) ;)
G-tech times
0-60....6.61 sec.
1/[email protected] MPH
my page.. http://www.geocities.com/shospd/index
its almost here!
pjtoledo
'ol man in the SHO
toledo,ohio,usa
What struts are you running? Last year the rear of my 92 MTX felt like I had no suspension at all, it was rock solid. Still have those same struts on, Tokico's, now with 110,000 miles on them. Waiting to see what they do this year.
Perry Toledo,Ohio
[This message has been edited by pjtoledo (edited 12-24-2001).]
SHO SPD
SHO member #480
Naples, Florida
I have all the factory suspention, they started to stiffen up earlier this year, but are now COMPLETELY solid, I Kid you NOT!
Your original struts were probably ready for retirement around 40,000 miles. Is there any hydraulic fluid visible on the external surfaces of the struts? Even if there isn't, your orignal equipment struts are most certainly worn out. Struts usually fail by leaking fluid at the shaft seal. Yours have probably rusted inside to the point of being immovable.
A note on the Tokicos. They have a lifetime warranty. I have received from Tokico a set of four struts to replace a set under warranty that had covered 125,000 miles. One strut developed a leak at the shaft seal. Even after 125,000 miles, I could not tell much of a performance difference with the new set. That is impressive.
Scott
1991, 253K miles, glass hood, police grill, SVO shifter, Catz fogs,
Eibach/Tokico/polyurethane, SHO Shop front & rear strut braces,
Class II hitch, Silver award at the SHOklahoma Car Show
SHO SPD
SHO member #480
Naples, Florida
Earlier this summer their was some brownish greasy oily stuff leacking from the rear of my car, could this be it? If so is it too tough to change them?
Blast7
Rochester, NY
I just had one strut freeze up on me today. I know I need new struts and springs but I hear the Tokico's are on backorder now. I will probably end up getting KYB GR2's and stock springs because I don't want to shell out the money for the Koni's.
Car of the Week
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
That "brownish greasy oily stuff" was most likely the hydraulic fluid from the strut(s). Without it, they can't dampen the vertical motion of the car and they are no longer lubricated and may eventually wear to the point of seizing. Struts have a lifetime. The OEM struts on the Gen Is only had a lifetime of around 40,000 miles. I believe you have gotten as much life out of them as possible. They are dead now. Put them to sleep. (That means your front struts too.)
Unless you have done some suspension work on your car, you may be better off paying a shop to do the job. It is a good 2-4 hours of work to replace the two rear struts/springs even with the right tools and the experience.
Scott
SHO SPD
SHO member #480
Naples, Florida
Thanks, yeah I guess I better get on that, I havent been driving it, the ride it just too rough, it literally shakes ALL of my insides! it hurts after a while. I will be doing the struts myself, I am very mechanically inclined, as I have help also from my 1989 car shop manual. Thanks for all the advise.
1989 Titanium pearl
CAI
K&N cone filter
G-tech times
0-60....6.61 sec.
Jan. 10 1:15pm
M
Mikeys_Taurus
Guest
Hmmmm well the rear struts don't scare me half as much as the front struts. Wowzers! There's a headache.
RJ-92
Crappy NYS
SHO SPD,
Give yourself a whole day to do all 4 by yourself. It took my bro an me about 9 or 10 hrs to do the Eibach/Koni thing. Oh, and have some acetaline handy. Those pinch bolts on the knuckles can be a Bee-atch
Ron Wazz
Red 92 MTX 109K
ss y-pipe,
dynomax cat-back w/1 superturbo & 1 ultra-flo muffler,
street/strip clutch,
18Lb. fly wheel,
ss tq limiters,
bored out MAF,
UDPs, ported intake
Konis and Eibachs, 26mm RSB
In storage for the winter
[email protected]
Albany, OR - USA
How much are the Tokicos, normally? I've seen Konis as low as $500 for all 4 at two or three different websites (http://www.prosuspension.com, http://www.iptech.tv, and I think http://www.shox.com had a good deal on them too).
I thought that Tokicos ran about the same...
Blast7
Rochester, NY
The Tokico's are around $440 for a set of 4. The Koni's are a little more expensive, and if I were to get Koni's I would spend another $150 on some stock struts to be the Koni inserts into. I don't trust the struts that are in there now. They could be bent, plus they are all rusty and I just like having all new parts put in.
Car of the Moment
1991 Black MTX
K&N Filtercharger
PP Motor Mounts
PP Y-pipe
Rod Shifter
Blazer Tech Fogs
"ur gonna love that sho, and everytime something breaks down..your gonna swear to all your friends that its going up for sale. and the minute you get it back you fall inlove all over again."~Blue
