Help installing Indiglo Reverse Glo Gauges
aaronsbiza
Sacramento, California
I just got my reverse glo gauges from ebay and the instructions are a bit to general. Has anyone else installed these gauges before and have some tips. If not is there anythiong to look for while dismantling the guages, or is there some instructions fro removing and dismantling the guages on the web? Another problem is removing the needles... The instructions state that on foreign cars you can slip the needle through the hole in the gauge being that the gauge is flexible. I know how easily the needles can break and am afraid to remove them... any suggestions? Any help would be most appreciated.
Bryan C. King
Norton, MA
Should be pretty close except for the color wires you need to hook up. I am getting my gauges in a few days for my 95. When I do I'll let you know what color wires I used and I'll take some pics
SHO_of_SD
Sioux Falls, SD, USA
If you want to have them hooked to your park lamps I believe it is the brown wire coming out of the headlight switch, when I installed mine I don't remeber if I used a black wire out of the headlight switch or if I just found some bare metal. Good luck on install, my set didn't need then needles removed. Very easy install I thought
Bryan C. King
Norton, MA
Just got the gauges today and installed them tonight on my 95 MTX. Very east install just like my 97. The wire to use is a brown wire for the parking lights/running lights, see attached picture. I just used a ground on the dash somewhere.
