help i killed my radio
MYSHO1
PiCkLe DaNcE!
Wakefield Ma, e.p RI
Well, this moring when i got up i learned that my car has a draw coming form it somewhere :squint: , because my battery was dead. When i went to jump it i pulled the 95 out and hooked my the 92 then went over to the 95, i somw how ( did not mean to at all) hit the positive terminal on the 95 with the neg from the 92 :bonk: .. well after jumping i now have no power in the amp or radio whats up with this? :shrug:
NiNeTy Fo SHO
No-mo-SHO Man
Troy, Ohio
My first guess would be that you could have blown a fuse either under the hood or in the fuse box inside the car. I would check the fuse for the radio/amp inside the car first. Look in the owners manual...lookup fuses in the back..and when you go to the page, it tells you what each fuse powers and its location.
Just my first thoughts... :corn:
