95SHOdude
First, this may take a few lines to explain. I'm very mechanicaly inclined but this ones got me scratching my head. shrug Sorry in advance for the long post.
I was driving about 70 and she started to buck. Looked down and the tach bounced a few time. Then she cleared up. I knew my water pump was going (90K on the engine) so I figured CPS geting hot. I replaced the CPS at 60K but not the WP (tight on cash)
. Anyway after a few of these the CEL came on. I pressed on. Then she shut down like the motor was turned off. I had her towed home and ran the codes (212, 524, 543). cry
I decided that now that I had a little cash stashed, I might as well fix everthing I knew needed repairing. thumb Here's what's been changed this week: Water pump, CPS, Timing belt, Motor mount, and fuel pump. The Alt, starter and batt are less than a year old. I repaced the Crank sensor at 80 as well as plugs and wires.
Now here's the problem: no power to the starter or fuel pump. I turn the key and no hum. I pulled out the relay and nothing shows shorted but I haven't tried power to it while testing. All my accessories work, lights, alarm, radio etc but nothing with the starter. No click or anything. When she died on me I did smell electrical burn smell but no fues were blown, both under the hood or under the dash. headbang
I've replaced and checked everything mechanical so now my question leads to electrical. Can a computer go out but store and show codes? I figured all or nothing on that one. Next, could the relay for the fuel pump cause the car not to want to turn over? And finally, could something as simple as my ingnition switch have caused this. Why would I get power to everything but a running car? cuss
Thanks in advance for any replys. I've learned alot from this form and hoping you can help me out. hail
