Help, dead SHO, electrical or mechanical or both?
95SHOdude
Houston, TX
cuss Third starter took a dump. Just pulled it off the car and half the teeth are fried. It looks like it locked up last time it started and the flywheel chewed the **** out of it. I'm off to trade it back in for yet another AutoZone rebuild. Hopefuly I'll be running this weekend. thumb
projectSHO89
SHOless In St L
Once the replacement starter is installed, you will still have to pinpoint the cause of the lack of the solenoid drive power. You mentioned and aftermarket alarm. These often come with a starter interrupt feature. On an MTX equipped car, this is most commonly inserted in the same circuit line that is missing power. If you are familiar with the installation of the alarm, keep this in mind as you troubleshoot.
According to the schematic: The main battery feed to the starter should be a RED cable and is connected directly to the positive terminal of the battery. The schematic shows a BLK/OR wire also going to a starter terminal - this is supplied via a pair of parallel fusible links.
Start at the clutch interrupt switch. One wire (WT/PK) should be hot whenever the ignition switch is in START. If so, check the other wire (R/LB) on the interrupt switch with the pedal depressed and as above. If battery voltage is measured on both terminals of the switch but not on the starter S terminal, there is an open circuit between the switch and the starter.
If no voltage was measured at the switch, check the engine compartment fuse box F1 & F2. Also, look for an interrupt switch as above.
Steve
95SHOdude
Houston, TX
Thanks, I went ahead and bypassed the clutch switch. I've been driving standards for over two decades and never needed one. The alarm is a dealer alarm that uses the Ford remotes. The starter/ignition circuit(s) checked out OK. I'm sure the problem was the fried started basicly going to ground. It won't even turn over out of the car with direct power feed. Just draws all the amps available and heats up.
I'll post if everything is fixed after I get my new starter. I think I got the last Autozone SHO starter in Houston a couple of months ago. They are hoping to have one by Monday but I'm not holding my breath. I should have gone with my gut feel when I got that one. It looked pretty beat up but like I said it was the only one in Houston they had. Since you have wiring diagrams if the starter shorted out could that cause a sneak circuit back to the CCRM? If so, that may be what cause that burnt trace in there. I doubt it but it's worth asking. I'm sure it was coincidence that my fuel pump also went out (95K on it). It probably drew enough current to burn the trace without poping any fuses. Weird but that's the best I can make of it.
95SHOdude
Houston, TX
New starter arrived today. After installing it and jumping the batt she fired up. I think I have a electrical gremlin. The ac display blinked on and off and it sounded like the starter was tring to engange. That would explain my last starter being chewed up. I think it's the ignition switch it has a bunch of play in it. Guess that's next on the list. I made sure that it wasn't to far forward and it seem to go away or at least not happen again. Tomarrow will be the test when I drive 180 miles round trip for work. Hope I'm not stranded on the side of the road again. cry
At least my neighbor now has a flat trailer and said he'll come get me next time it happens. :D
