heater core replacement question im stuck
brandon1186
ontario
i am all the way to removing the ac lines from the firewall i have the top one released how do i gain access to the second lower one? this is one **** of a job i have never seen something so time consuming!
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
Same way you got to the other one. I remember pulling my intake so I could lay down across the motor cause mine were being picky too. What would help out is if you can loosen some of the stuff holding that hard line so you can twist it a little when you try to stick that peice in there.
Eric VerValin
PiMPSKiLLET
Fort Wayne, Indiana
I remember tryin to get in thru the wheel well, but I could only get 1 hand on it. Might be cool if you had a second person grab it in the wheel well area there and push / pull / twist it while you try to get that "tool" in there.
