Heat Help!!
OhioGuy82
Portsmouth
It's oh so cold lately. I would really like to have heat blowing through the panel vents or even the floor. I only have defrost ducts blowing air. It seems to be hot, there's just not enough blowing out to make the car warm. The blower is working strong. I can clearly hear it. The speed control works as well. When I try to select Panel/Floor/Defrost. I can hear some movement, just nothing is happening! Is there anything I can do to force air to blow through the panel or floor?
OhioGuy82
Portsmouth
I found that the vacuum line running outside of the firewall is detached! Where does that go?
