shoon
cliTaurus
My car is parked outside till I get it on the road, and today noticed the headlights were dimly glowing; the high beam indicator on the dash also glows slightly even with the ignition off (key removed) and headlamp switch turned off.
Autolamps is also turned off.
I tried toggling / wiggling the headlamp switch and engaging / disengaging the ebrake to get them to go out but they still stay on. even messed with the autolamps switch but it still stays on. I ended up pulling the 20 amp fuse on circuit #10 to get them to go out.
the fact they just came on all of a sudden leads me to believe its an intermittent electrical issue, probably moisture got in somewhere where it shouldn't be.
It's just the front headlamps.. the taillights do not light.
Anyone else have this problem?
