Headlight switch bulb out. How do I replace?
spazmoid
RI
are you sure they even have a bulb? I have a 94 too and i don't think mine's even been lit up. I think they might be made to glow in the dark, but i'm really not sure.
Sho-Driver
Peter Pan
The Garage.
Yes, they do. Remove the lower metal cover, the remove the bezel. The bulb will twist out. It is very tiny and you can get it at Auto Zone.
ES_8CH_OH
White '94 ATX
Malvern, PennSHOvania
Lower metal cover... is this near the auto dim switch? Or do I take the black instrument cluster surround out?
Sho-Driver
Peter Pan
The Garage.
It is the big cover under the steering wheel. There are four torx screws holding it in. The bezel is held in by two smaller torx screws underneath. The bezel is also held in by two above the gauges. When pulling the bezel, pop out the radio controls, fog light switch, defroster botton, and disconnect the clock from the back. If you want to pull the bezel completely out, you will need to pull the head light switch out by pulling out on the black switch and removing the nut behind it.
