head gasket
john buck
SHObuck
Cookeville, Tennessee
my 1990 mtx suddenly lost power....so i checked the plugs and this is what i found... the front 3 were chalky and white looking.......the passenger rear one was identical to the front three... but the other two rear ones were black, covered in oil and dripping wet, and they smelled burnt...i figured i had a blown head gasket or a cracked head......any more suggestions...thanks for any help. john
CerberuS
300 HP N/A SHO
Granby, QC, Canada
warped/cracked heads or blown gasket is EXTREMELY rare on a SHO. But not impossible.
The white plugs surely points that way. It could mean your burning coolant or that your running lean.
Hows the level of your coolant in the rad? Any white smoke?
The oily ones only mean you need a valve cover gasket , they leak inside the plug wells.
john buck
SHObuck
the coolant level is fine.....it does smoke like all getout though.....would using coolant effect the power though.... ive had honda d16s pullin ******* me and thats bad lol.....
john buck
SHObuck
yes the engine light will come on once you drive for about ten minutes. i tried to have them checked but no parts store around has the obd1.
projectSHO89
SHOless In St L
All you need is a paperclip. No scan tool needed.
Steve
AREA 91
PA SHO SHOP
Area 91
Check your oil and coolant levels. Also make sure that they aren't mixing together.
